15 years agoMAXII LED Driver AN286
Hello, the AN 286 decribes implementing LED Drivers in MAX devices. The maximum source/sink current is dependend on the number of GNDIO/VCCIO groups. Is a group identical to the number of ...
15 years agoThe answer from Altera support makes me a little bit confused.
Does anybody understand the answer of Q2? If I have a look in the pin out file of EPM2210 I count 20 regions... Volker Following the anser of the support: [Q1]: Is a group identical to the number of GNDIO/VCCio pins? [A1]: A group means a set of I/O pins between any two VCCIO pads or any two GNDIO pads. As an example is quoted in the handbook, the EPM240 device has six GNDIO pads, which provide six I/O regions that can sink up to 130mΑ. If you need to sink 15mA for the outputs, you can have eight outputs per region. With the six regions of I/O between GNDIO pads, there are 48 possible outputs, each sinking 15mA. For more information about GNDIO grouping, refer to the MAX II Device Pin-Out Files, and the MAX 7000B Device Pin-Out Files. These files are on the Pin-Outs page of the Literature section of the Altera website. [Q2]: Is it theoretical possible to sink 16x 130mA using a MAXII EPM2210 (16 VCCIO/ 16 GNDIO pins)? [A2]: No, the maximum sink current per group is 130mA, as stated in AN 286 application note, Table 3: Maximum Source Current for Each VCCIO Group and Maximum Sink Current for Each GNDIO Group in MAX and MAX II Devices. 16 x 130mA = 2080mA is already exceed the 130mA maximum rating, which may have adverse affects on the device.
