13 years agoMAXII + PFL + CFI Flash word-programming format?
Another day, another problem! My design uses the PFL in a MAXII to load either a user configuration or factory configuration from a P30 flash via FPP. When programming the flash via JTAG/MAXII/...
13 years agoA quick read through the PFL guide ...
http://www.altera.com/literature/ug/ug_pfl.pdf p14 talks about options bits. Is that what you are seeing in your image? Cheers, Dave
