15 years agoMAX7000AE programming issue
Hello All,
The background is that we have some boards that were created by our company some 5 or 6 years ago. There is no one left who was involved with the project. We found one board that was programmed and a number of others that were not. I now need to get the image off of the one programmed board and get it onto the other boards. I am not quite sure where to start as this is my first time using an Altera product. Thanks.2 Replies
--- Quote Start --- if i recall, i read that there are certain bits that are set only during the programing phase, and data can only be changed when those bits are set. --- Quote End --- It's rather the other way around. The device can be freely copied, unless the security bit has been set intentionally. --- Quote Start --- I am not quite sure where to start as this is my first time using an Altera product. --- Quote End --- Supposed, the boards have the JTAG pins of the device exposed to a 10-pin connector according to the Altera standard, you need an Altera programming adapter (e.g. USB Blaster) and Quartus II or an Altera-standalone-programmer (ASAP) installed. Read-back the image ("interrogate") and writing it to another device in the programmer window can be done almost intutively. - Altera_Forum
i am fairly sure you cannot rip the code off of a programmed device.
