Gigiz's avatar
Gigiz
4 years ago
MAX10M04 / Quartus Prime Lite Edition
Good morning,
I'm completing a project with MAX10M04 FPGA and Quartus Prime 20.1 Lite Edition software.
The project is in the final phase, everything works fine but I have a very strange problem: I used the schematic for the whole FPGA project and using the same component I built "1Encoder" four times it gives me problems just by connecting the hardware of the 4th component.
Not connecting this all the whole project works perfectly.
Are there any limitations using the "Lite Edition"?
I attach the FPGA project and the wiring diagram of my board.
  • Nurina's avatar
    Nurina
    Hi Gigi,
    Sorry for coming back to you so late.
    You can perform this on the Lite version. You first need to specify your EDA tool.
    Go to Assignments->Settings->EDA Tool Settings then set to ModelSim or ModelSim-Altera
    Then under Tools->Options->General->EDA Tool Options set the path of the tool you chose to "C:/intelFPGA_lite/20.1/modelsim_ase/win32aloem"
    You can also try SignalTap, this would allow you to spot check a couple I/O signals and observe the signals.
    Nurina
    • Nurina's avatar
      Nurina
      Hi Gigi,
      We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
      Nurina
      PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
  • Gigiz's avatar
    Gigiz
    Hello Nurina,
    I have not solve the problem yet.
    Gigi
  • Nurina's avatar
    Nurina
    Hi Gigi,
    I suggest you open a new case if you come across a problem in the future so that it will be easier for the community to navigate in case they come across the same problem as you are now dealing with a different tool on Quartus.
    Nurina
  • Gigiz's avatar
    Gigiz
    Hello Nurina,
    I want to inform you that I have solved the problem, thanks.
    Gigi
