9 years agoMAX10 with NIOS does not start program code
Hi All, I have a very peculiar issue. I have a MAX10 10M08SCE144 with a NIOS core that I am trying to get to run at reset. So I got hold of AN730 which describes how to make sure the device i...
9 years agoHi Guys,
Some very sage advice, thank you. I have actually already done some of these things. I have reduced drivers set in my BSP and as far as I am aware the flash is in the same clock domain as it is connected to the only clock in the system Qsys system along with the NIOS II/f core. One peculiarity is that it seems to be application (and therefore possibly size) related, the reason I say that is that if I put in a different application code (smaller in size) the bootloader works, however when I put the code I want to run into the application, it does not boot after power cycling. A further oddity is that after powering up (and nothing booting), if I press the reset or toggle nConfig, the system runs the code! Very odd. I am quite confused. Thank you for all your help so far. deBoogle
