TWell6
6 years agoMAX10 Timing Constraints for a Clock Enable fanout?
I'm working on a project for a MAX10 FPGA, using a clock enable, ClkEnBuffer, which reduces the clock speed by 4. I've had a look at a Timing Analyzer example (https://www.intel.com/content/www/us/e...
- 6 years ago
Your hold multicycle value should be one less than your setup multicycle, so it should be 3 instead of 1. The example you link to has enable every other cycle which is why 2 and 1 are used there. You need to use 4 and 3 for your enable every 4 cycles. Try that and report back.
#iwork4intel
TWell6
6 years agoAs I put on the original question:
> Quartus: Quartus Prime Lite 19.1.0 Edition
