10 years agoMAX10 single or dual config? ADC yes or no => (dual flash + watchdog) yes or no
After reading "all" confusing docus and playing with Quartus II I realized (not written ANYWHERE) that chips with analog-to-digital-converter have dual boot configuration possible. But chips wi...
10 years ago --- Quote Start --- From this: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/pt/max-10-product-table.pdf It looks like they all have dual configuration except the low end device (10M02). --- Quote End --- Exactly this is the main document and completely confusing! If you try Quartus II you will see that for low end there is no possibility to select dual configuration. Having this in mind I was focusing to search on this phenomene.... An I found somewhere in Japan from Altera training attached table This table confirms that Compact devices (No ADC) do not have double configuration and also (I believe) watchdog (no possible to enable it in Quartus unless you have dual configuration)
