MAX10 (Select Internal Configuration mode with ERAM )
(After researching issues about error 16031, I edited this post)
I'm facing the same issue.
Quartus Lite edition 21.1.1
Target device MAX10 10M50SCE144C8G
I use Nios-II processor and internal flash (without initializing), and now implemented DPRAM and LUT (ROM) with initialization file (.mif) for logics.
Questa sim is ok, but when I tried to synth. the same error 16031 was reported.
Viewing this thread, Configuration mode in "Device and Pin Options", only 2 options as the same as Yann12 wrote.
I've read other posts that MAX10 SC device will not support configuration with memory initialization.
So I understood RAM with memory initialization will not be capable for the selected device.
Then I regenerated DPRAM without initialization, its ok.
But curious thing, implementing LUT with memory initialization setting, synthesis and fitter have passed.
Does ROM IP can be used on SC device that does not support configuration with memory initialization?
Hideki Dekker. T
