11 years agoMAX10 (Select Internal Configuration mode with ERAM )
Hello, In Quartus 14.0 SP1, i can compile my max10 sopc project ( Platform: BeMicro MAX 10) all is running fine. Now i switched to Quartus 14.1 In this Version i can't compile my proje...
yann12
4 years agoHi, I try to configure a double port RAM on the DE10-Lite Board (10M50DCF484C7G) with a .mif file.
But the problem is when I synthesize the whole thing, I get an error :
"16031 current internal configuration mode does not support memory initialization or rom. select internal configuration mode with eram."
But... when i go into Device->Device and Pin Options->Configuration->Configuration Mode, i only see 2 options :
1. Single Compressed Image
2. Single Uncompressed Image
I do not see the option "Single uncompressed image with Memory Initialization" which would make the error above go away.
I try it on the 15.1 and 18.0 version, same issue...
Is there a solution to configure a mif file on this kind of board ?
Thanks for your help
Yann
