11 years agoMAX10 (Select Internal Configuration mode with ERAM )
Hello, In Quartus 14.0 SP1, i can compile my max10 sopc project ( Platform: BeMicro MAX 10) all is running fine. Now i switched to Quartus 14.1 In this Version i can't compile my proje...
11 years ago --- Quote Start --- The following worked for me: Assignments -> Device -> Device and Pin Options -> Configuration -> Configuration Mode: Single uncompressed image with Memory Initialization --- Quote End --- Hi, thanks for your answer, I have followed your instructions, but I have again received an error from the fitter. "14740 Configuration Mode parameter on atom "ufm block" is inconsistent with Quartus II project setting. MAX address parameter on atom "ufm block" is inconsistent with Quartus II project setting." I then opened qsys, and opened "Altera On-Chip Flash" IP. In the Parameters tab, under Configuration Mode, i set the Configuration mode also to "Single Uncompressed Image with Memory Initialization ! After compiling QSys, i can compile and run my MAX10 project.
