10 years agoMAX10 primitive TRI-state output buffer ERROR
All, I am converting a MAX-II design over to a MAX10. I get the error 12168 I/O primitive ALT_OUTBUF_TRI is not supported for the selected family (MAX 10). What/where can I find informat...
10 years agoMorning Alex,
OK, I guess I am not following what is going on. I can bring up my IP Catalog, but I can't find my ALT_OUTBUF_TRI to configure. I am doing a total schematic capture design. I also get an error that states that File extenstion (.bsf) is not supported for the IP variation files. I guess my design of programming of a chip or 2 every 3-4 years is a big drawback of trying to learn new software with a steep learning curve. Kindof why I liked 9.0 since it was simple, and had an integrated simulator, (without having to create a new project and then go find your .v?? file) Since my designs are simple I thought it should be a fairly easy: 1) load the original project (schematic) 2) reconfig for new device 3) recompile 4) test timing-waveform 5) layout new pin locations 6) done..... Any other suggestions on what I am doing wrong? My designs are schematic based, no Verilog or VHDL. Thanks, Keith
