Jo910
5 years agoMAX10: JTAG ISP
I plan to use a MAX 10M02SCE144I7G FPGA on my next PCB. FPGA code will be generated by Quartus. I know how to programm FPGA by using external JTAG header, but I want to programm FPGA with a Microprocessor via ISP. Is there another possibility to programm FPGA without using JTAG? What solution whould be the easiest way to implement a ISP for MAX 10 connected with a Microprocessor?
1 Reply
- NurAiman_M_Intel
Have you refer to Max10 configuration userguide for implementing ISP? It is recommended to follow Intel configuration userguide below for further information. Let us know your concern.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Aiman
