9 years agoMAX10: internal Pull-UP, enabing state
Hi, using MAX10 FPGA, is there a way to change the internal Pull-UP status (Enabled-Disabled) in user-mode? at the moment it is possible to do it only inside Quartus before generating the...
9 years agoInternal pull-up is set in configuration bit stream and can't be changed from FPGA fabric, similar to IO standard selection and drive strength.
