MAX10 Command line programming POF file does not work
about quartus_pgmw checked on opt/altera where I wrote some note about issue on install,
check if this can solve graphic version
ln -s /lib64/libudev.so.1 /lib64/libudev.so.0
copy simlink on /lib/x86_64-linux-gnu/
I am using Linux Mint and some new issue came from installation. Old good version 15.x is now broken and no more usable due to some recent library.
Issue like resize before use pll still is present from 14.x. Programmer appeared after 15.x and year by year still landed to 20.x no difference if lite or pro.
1) .pof still does not work when programming .sof first. I haven't seen the programmer hang forever, it will just fail with the error message, so I may not be experiencing the same issue.
2) This is on 19.1 version of programmer on Centos 7. I tried your suggestion to link those 2 files but it still opens a blank gui window that never runs. Thanks for the suggestion, though
Do you know how to use IPS files from the command line?
- RRomano0015 years ago
Contributor
Question 1: after attempt of programming a .pof file it accept a .sof or fail?
can be of help check jtagconfig on fresh boot then after sending a .pof file to see if jtag server remain active or not.Question 2: launching from terminal see nothing on output relative to missing library or error?
Lite_19_1 run smooth but output a huge warning about a missing lib "pixbuf" GdkPixbuf-CRITICAL
lite 20_x run without errors but still doesn't program .pof.
to program .pof you must go back to version 15 or previous, older version exhibit the empty windows you mention too. (checked now it work fine too like 19.x)
Question 3: its since 80th not use command line to program devices and never used IPS mode maybe one time when I embraced Altera near 2004 to automate maxII programming.
At last I suggest take an eye here to see if it cam be of some help:
https://sudonull.com/post/64660-JTAG-network-programmer-for-Altera-Quartus-Prime-from-Raspberry-Pi3
Best wishes
