rt52
5 years agoMAX10 Command line programming POF file does not work
I have a Max10 based custom board that I access remotely in order to perform tests. I have installed the Quartus programmer for Linux (centos7) on this machine and can currently use the following co...
RRomano001
Contributor
5 years agoHello, old version before presume 16.x was not suffering this issue.
Try program a .sof in advance of .pof
When .pof is sent to device programmer hang and jtagd deamon need be shut down.
The only command work forever is erase.
Blank check verify program fail no difference if Byte blaster is original one, terasic embedded or simple cheap china device.
Also observed weird interaction with Saleae Logic8 and Stlink v2, when combined sometimes USB subsystem crash and you need reboot. Try'd init without success, only shutdown solve.
