10 years agoMAX10 can’t erase CFM when niosii run from UFM
When I try erase CFMx or UFM (may be write also) the On-Chip Flash Status Register return 2'b11-BUSY_READ
If I start this program from internal RAM(?) – in eclipse: Run As -> choose NIOS II Hardware – "erase" work correctly. May be CFM and UFM write protected when program run from UFM? PS: protection bits sets correctly, I try erase CFM1,2 when work from CFM0 and vice versa MAX10 dual compressed images MAX10 Remote System Upgrade over UART with Nios II Processor Quartus 15.1 MAX10-10M08SAE144C8GNo RepliesBe the first to reply
