9 years agoMAX10 : Error (169049): Enable Bus-Hold Circuitry and Weak Pull-Up Resistor logic
Error (169049): Enable Bus-Hold Circuitry and Weak Pull-Up Resistor logic options cannot both be enabled for ~ALTERA_TMS~ pin
Error (169049): Enable Bus-Hold Circuitry and Weak Pull-Up Resistor logic options cannot both be enabled for ~ALTERA_TDI~ pin Using Altera MAX10 Dev Kit 10M08SAE144C8G Quartus Prime Lite 16.0.0 Edit Settings Compiler Settings Advanced Fitter Settings Enable Bus-Hold Circuitry = ON MAX10 TMS and TDI have on IC weak pull ups - so the SW thinks there is a problem with TMS and TDI. Weak pull-ups ARE NOT turned on. Any ideas on this? My goal is to get bus-hold enabled on the MAX10 pins during user mode.No RepliesBe the first to reply
