15 years ago
Max V static VCCINT current higher than expected
Has anyone else experienced higher than expected static current consumption on the VCCINT supply for Max V devices?
I am prototyping with the 5M240ZT100C5N part. The PowerPlay analyzer says I should have about 0.02mA of static VCCINT current. However, I am measuring more like 4.5mA. Dynamic current is as expected.
Nothing else is connected the 1.8V regulator. I am wondering if these devices are meeting their static power spec.
Tyler
    --- Quote Start ---
    Also, this high static power consumption is for 1.8V Core power supply.
    --- Quote End ---
    Yes. The pull-ups won't matter. Floating inputs could cause oscillations that also effect the idle current.
    You should ask Altera support.
    Hi FvM,
    Thanks for the response.
    No floating inputs or grounded pull-ups.
    Tyler
    Do you have floating inputs or inputs with pull-up connected to ground?
