10 years agoMAX-V scalability
Hi, I am going to use MAX-V type 5M570ZF256 on my new board and I would like to upgrade in future to 5M1270ZF256. But I found that each of these two versions has a single GND pin which is not...
10 years agoQuartus allows you to build device migration into a project. Under 'Assignments' -> 'Device', click on the 'Migration Devices' button bottom left. Select all the devices you wish to support. Quartus will then generate a device pin file suitable for use with any of your chosen devices.
Cheers, Alex
