15 years agoMax V Power Consumption - How to determine toggle rate SIPO/PISO?
Hello all, I'm using 3 Max V 240Z for an implementation of a 320 bit serial in parallel out (SIPO) shift register. This shift register will be the driving end of an automotive wiring harness. ...
15 years agoI have no experience trying to estimate the toggle rates.
What I've always done is to write a realistic test bench, run it in ModelSim recording the VCD file and then use the VCD file for the power analyzer. http://www.altera.com/support/software/power/sof-qts-power.html
