13 years agoMax V output pin in a disconnected mode on logic 1
I'm using Max V dev kit for basic logic gate design. No clocking or anything. Logic part works fine. On logic 1 / high I would like the output pin to be floating / disconnected. Right now it pr...
13 years agorbugalho - I re-read your comments and tried the Max V in circuit and all voltage levels look good with the Tri state buffer on the output.
FvM - thank you for the advice I will make that change to clean up the design. thanks everyone for the great help
