13 years agoMax V output pin in a disconnected mode on logic 1
I'm using Max V dev kit for basic logic gate design. No clocking or anything. Logic part works fine. On logic 1 / high I would like the output pin to be floating / disconnected. Right now it pr...
13 years agoI found tri buffer in schematic editor and looks like I can add not gate to the control pin such that
- if output is 0 then not gate will invert and cause 1 on buffer control pin, so that my input of 0 = output of 0 - if my output is 1, then not gate will invert and cause 0 on buffer control pin and this will cause high impedance Output of tri buffer seems to be valid for output pin per the docs I found. Going to try in 30 minutes. thanks for the help
