14 years agoMAX V LE RAM - how much per LE ?
Seems Altera really like to hide the simplest information. The MAX V data says the quartus ii memory compiler can configure the unused les as le ram. max v devices support the following memor...
14 years ago --- Quote Start --- Can anyone point to an answer to this ? is it 1, or 8, or 16 or ? RAM Bits/LE --- Quote End --- It's < 1. You have one memory bit per LE, but usually need additional LE's for address decoding and an output MUX. Very small RAMs like the said 12x4 should work. Why don't you simply try in Quartus?
