13 years ago
max v jtag resistors
I followed the app note for jtag with Max 7000S and it works perfect. I'm switching over to 5M40ZE64C5N, are the 10k and 1k resistor still required?
Also I'm switching from 5v with Max 7000S to 1.8v only for Max V, will there be any issue with JTAG ISP? I'm using USB Blaster.
thanks!
1 Reply
    ok found the answer:
    For MAX V devices, there are weak pull-up resistors for
    TDI
    and
    TMS
    , and pull-down
    resistors for
    TCK
    . However, in a JTAG chain, there might be some devices that do not
    have internal pull-up or pull-down resistors. In this case, Altera recommends pulling
    the
    TMS
    pin high (through an external 10-k
    resistor), and pulling
    TCK
    low (through an
    external 1-k
    resistor) during BST or in-system programmability (ISP) to prevent the
    TAP controller from going into an unintended state. Pulling-up the
    TDI
    signal
    externally for the MAX V device is optional.
