11 years agoMAX V & Board Test System
I just got the MAX V kit. I'm learning to work with the kit. I installed quartus II 14.0 64 bit web edition on c:\Altera\14.0 folder . Also install the Max V develompent kit 11.1 on c:\altera\11.1\kits folder. I install the driver and can see it under device manager . USB Blaster. I plug the board to the PC USB and the blue light turn ON. Although , when I try to run Board Test System.exe software - nothing happens ?? No error , nothing hangs in the PC memory. simply nothing . Any reason ? I try on 2 computers Win7 64 bit . Thanks , T.Z.11 Replies
Does the kit appear in device manager when you plug it it? It should be listed as 'Altera USB-Blaster II' or similar under the 'Universal Serial Bus Controllers' or 'JTAG cables' - or possibly another category that'll appear/disappear as you plug the board in & out.
Cheers, Alex
