11 years agoMAX V & Board Test System
Hello, I just got the MAX V kit. I'm learning to work with the kit. I installed quartus II 14.0 64 bit web edition on c:\Altera\14.0 folder . Also install the Max V develompent kit 11.1 o...
11 years agoI had the same problem but with a Max10 RevB kit. I tried the RevC kit and it worked. Maybe its a version issue for you? Also, once connected it kept giving me error "No JTAG detected or selected". I fixed that by setting the DIP switches on the Max10 dev board to the default settings. Just wanted to share my experience with BTS. Hope this helps.
Good Luck!
