14 years ago
MAX_FANOUT problem
Hi
I have set a global fanout constraint to 25 and the tool is also inserting cells as shown in the info generated.
But still when i see the fitter report there are NON-GLOBAL signals with fanouts of 400 .
Even by using the assignment editor if i set the instance fanout assignments for those signals the tool is accepting it and no report for ignored fanout assignments are genrated but still the signals are having the same fanout if i check the fitter rpt.
The state is quite confusing that the assignment is not ignored and not even implemented.
Please guide me with this.
    Synthesis report <project>.map.rpt has "Registers Duplicated to Honor Maximum Fanout Requirements" section.
    It lists all the registers, required fanout and number of duplicated registers created for those registers.
    Evgeni
    There could be answer that the signals are outputs of a combinatorial black and the max_fanout constraint applies only to registers .
    Is there a way to constraint the fanouts of combinatorial blocks.
