13 years agoMAX 7000 Help
Hello, I am using the EPM7128S and all I am trying to do is make the pins high (5v) or low (0V), but I'm not having any luck. This is my first time using this chip. For example here is the co...
13 years agoThank you rbugalho you have been very helpful. I got all my pin assignment done and it compiles! I am working on the control statements and I must be having syntax problems again. I tried using the same syntax as the tutorial in the help menu, but it didn't work. Here is my "if" statement:
Any thoughts? (it wouldn't let me submit a reply with the code for some reason so I attached it in a txt file)
