13 years agoMAX 7000 Help
Hello, I am using the EPM7128S and all I am trying to do is make the pins high (5v) or low (0V), but I'm not having any luck. This is my first time using this chip. For example here is the co...
13 years agoThank you. That worked perfectly. So I will only compile when I am done? The reason I ask is I have a sample .jam file that I was able to load on to the chip. I figured the compile would convert the Verilog to the .jam file. Or is this done with a different process?
