13 years agoMAX 7000 Help
Hello, I am using the EPM7128S and all I am trying to do is make the pins high (5v) or low (0V), but I'm not having any luck. This is my first time using this chip. For example here is the co...
13 years agoYour Verilog syntax is wrong. And I guess you're misunderstanding how pin assignment is done.
what you want is something likemodule testing_123(
output wire ctrl0
assign ctrl0 = 1'b0;
endmodule
Then you synthesize the design. It should work, and you should get some warnings about assigned pins. You don't assign actual pins in the Verilog code though. Then you go to the Pin Assignment Editor and you assign I/O signals of your top level entity to FPGA pins. In this case, I guess you want to assign "ctrl0" to "PIN_10".
