MAX 10 pinouts
I'm laying out a PCB for MAX 10's 10M08/16SAU169C8G. I would like to have a pinout document for both the 10M08SAU169C8G and the 10M16SAU169C8G. FPGAs.
I can't find the pinout documents for either part. In the Intel MAX 10 FPGA Device Family Pin Connection guide it says: Intel recommends creating a design, enter I/O assignments and compile the design then Intel Quartus Prime software will check pin connections. I have done this.
This is all well and good but Pin Planner doesn't help me with specific pins (i.e. which CLKx_p is CLK_p on pin C10 and which CLKx_n is it's complement). I need to know what signal a specific pin is used for to be able to create my PCB..
Would someone direct me to the solution to my problem?
- Ash_R_Altera
Pinout files for all the devices can be found on the following link:
Pin-Out Files for Intel Field Programmable Gate Arrays (FPGAs) | Intel
- c75
Can you also provide pinout for the 144LQFP, 10M02SCE144C8G?
- JFK
Thanks Ash_R_Intel,
This is exactly what I was looking for.
JFK
- Ash_R_Altera
The Pin planner shows pins with p and n in hexagon boxes. For 10M08SAU169C8G, C10 pin is a 'p' pin and corresponding 'n' pin is C9. If you hover your cursor over these pins, you will find names as DIFFOUT_T14p and DIFFOUT_T14n. You can also check the pin properties.
Attaching the pinout files in CSV format.
