8 years agoMAX 10: a clock for SPI
Is using an external clock without a clock buffer causing any problem? I'm implementing SPI slave. An external SPI clock is directly from a pin(not a clock pin, but just an IOpin) of the FPGA...
8 years agoBe careful, your design is not fully synchronous so it complicates the timing constraints.
You should not have in_CSn in your sensitivity list to be fully synchronous with the sclk signal, and in your case, you probably want to be synchronous with sclk. --- Quote Start --- always @(negedge sclk or posedge in_CSn) if (in_CSn) Cnt <= 3'd7; else if (Cnt == 3'd0) Cnt <= 3'd0; else Cnt <= Cnt - 1'b1; --- Quote End ---
