8 years agoMAX 10: a clock for SPI
Is using an external clock without a clock buffer causing any problem? I'm implementing SPI slave. An external SPI clock is directly from a pin(not a clock pin, but just an IOpin) of the FPGA...
8 years agoThanks Alex for our reply!
- How have you constrained your design? Not yet, cause I thought actual this SPI clock (sclk) is not that fast as less than 50 Mhz. Please give me some hints. I recently moved from Xilinx to Altera. I'm going to look at tutorial adding constraint file, but I'll be happy if you give me some tips making less mistakes. Regards,
