15 years agomatrix array in vhdl
Dear all, I have 4x4 matrix and I want to read this matrix row by row on each clock cycle. For example, row1 is read in cycle1, row2 is read in cycle2 and so on. Can anyone give idea how to w...
15 years agoThis is my transpose code:
package newtype is type matrix_t is array (0 to 8, 0 to 8) of integer; end newtype; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.newtype.all; entity transpose is port(input: in matrix_t; clk: in std_logic; transposed_matrix: out matrix_t); end transpose; architecture arch of transpose is function change (matrix: matrix_t) return matrix_t is variable ret: matrix_t; begin for i in matrix'range(1) loop for j in matrix'range(2) loop ret (j,i):= matrix (i,j); end loop; end loop; return ret; end function; begin transposed_matrix <= change (input); end arch; The same error with my previous code that not use a function is occurs; Error: Design requires 5185 I/O resources -- too many to fit in 1264 available in the selected device or any device in the device family. Why the same error still occurs? I confuse now, need your helps. Many thanks.
