15 years agomatrix array in vhdl
Dear all, I have 4x4 matrix and I want to read this matrix row by row on each clock cycle. For example, row1 is read in cycle1, row2 is read in cycle2 and so on. Can anyone give idea how to w...
15 years agoDear Tricky,
I have simulate the code and the result shows that the 4x4 input matrix does not obtain in the correct clock cycle. All the rows obtain at the same clock cycle in one time. Below is the main code and testbench: ---main code package newtype is type row_t is array(0 to 3) of integer; type matrix_t is array(0 to 3, 0 to 3) of integer; end newtype; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.newtype.all; entity test is port(input: in matrix_t; clk: in std_logic); end test; architecture arch of test is signal matrix : matrix_t; signal temp_row : row_t; signal count : unsigned(1 downto 0) := "0"; function extract_row( m : matrix_t; row : integer) return row_t is variable ret : row_t; begin for i in row_t'range loop ret(i) := m(row, i); end loop; return ret; end function; begin process(clk) begin if rising_edge(clk) then temp_row <= extract_row( matrix, to_integer(count) ); count <= count + 1; end if; end process; end arch; ---testbench library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_Std.all; use work.newtype.all; entity test_tb is end; architecture bench of test_tb is component test port(input: in matrix_t; clk: in std_logic); end component; signal input: matrix_t; signal clk: std_logic; constant clock_period: time := 10 ns; signal stop_the_clock: boolean; begin uut: test port map ( input => input, clk => clk ); stimulus: process begin input <= ((0,1,2,9), (3,5,6,10), (9,8,11,2), (9,7,1,6)); wait for 50ns; stop_the_clock <= true; wait; end process; clocking: process begin while not stop_the_clock loop clk <= '1', '0' after clock_period / 2; wait for clock_period; end loop; wait; end process; end; What the mistake I have done? Help me please..thanks foR reply
