15 years agoLWIP problem
hi,
I am sending and receiving data using LWIP for lan communication. Here in SOPC builder design I am putting high_res_timer and sys_clk_timer 10 us and 10 ms respectively .The problem what I am facing is LAN is going to to get stop sending/receiving data after some time. This duration get change when i changed the timers duration. Is there any guidelines is there that what value of timers I should I put? Thanks in Advance!1 Reply
Check timer registers. It increases every step You've set in the SOPC.
