15 years agoLVPECL with VCC of 3.3V on a Cyclone3
Hi, Is it possible to use LVPECL signals on a bank that has VCCIO = +3.3V? I am using a Cyclone3 part. Thanks
15 years agoThe problem is, that Cyclone III doesn't provide a differential input standard for VCCIO of 1.8V. You are able to divide down a single ended PECL output to met the SSTL-18 reference voltage, but the signal swing is below the specification, and I fear, the level will be also affected by temperatur variations. Without a true differential input, it's difficult to achieve reliable operation.
Setting the comparators VCCO to minimal speicified 2.7V may bring you nearer to an acceptable solution. Personally, I would prefer external LVDS receivers.
