13 years agoLVDS_TX no output
Hi, I have a problem with the mega function LVDS_TX. Nothing is coming out of it! I check with SignalTap the "in" signal and they are good. It's for a DAC3282. I have 32 bit input,...
13 years agoAre you using an internal PLL or external PLL? The being said, even if you use an external PLL and set it up incorrectly, you should see something toggling on the output. Is SignalTap using the same clock as the parallel clock for altlvds? (My guess is the clock isn't toggling, but if SignalTap is running off of it, then it is). Worst case, remove the altlvds block and just send some toggling data out to make sure that works.
