15 years agoLVDS signal as the input of ccd sensor?
Can I use a low-voltage differential signaling (LVDS) signal as the input of kai-1020 image sensor driving signals? thanks
15 years ago --- Quote Start --- Which signals are you referring to? As far as I see, the chip requires mostl 5V CMOS drivers, partly high strength and level shifting. --- Quote End --- Thanks for reply. In my design ,the sn74alvc164245 be used between the fpga and ccd sensor.
