15 years agoLVDS signal as the input of ccd sensor?
Can I use a low-voltage differential signaling (LVDS) signal as the input of kai-1020 image sensor driving signals? thanks
15 years ago --- Quote Start --- If the sensor outputs are LVDS then yes, you can. --- Quote End --- what i say is that the sensor be drived by FPGA. ccd drive signal level 1.Pulse Amplitudes -ccd drive signal ? Clock Min. Amplitude (volts) Coupling Min. Coupling Capacitor Value (μF) Max. Coupling Capacitor Value (μF) SH 3.5 DC -- -- H1 4.7 AC 0.1 0.47 H2 4.7 AC 0.1 0.47 SA 4.7 AC 0.01 0.47 SB 4.7 AC 0.01 0.47 R 4.7 AC 0.01 0.47 T 4.7 AC 0.01 0.47 V1 4.0 AC 0.01 0.47 V2A 4.0 AC 0.01 0.47 V2B 4.0 AC 0.01 0.47 FD 4.0 AC 0.1 0.47
