14 years agoLVDS_RX and ADC
I'm using an AFE5808EVM from TI. It is an 8 channel ADC that utilizes LVDS to offload sampled data. The clock rate is 40MHz, adc resolution is 12bit. I set up an LVDS_RX megafunction with the f...
14 years agoI don't understand what's the difference beween your "data clock" and "frame" signal in the diagram?
The ADC frame clock ("slow" clock) would be connected to the RX PLL input and the bit clock ("fast" clock) generated internally. Setting the sampling phase correctly may be another issue.
