14 years agoLVDS_RX and ADC
I'm using an AFE5808EVM from TI. It is an 8 channel ADC that utilizes LVDS to offload sampled data. The clock rate is 40MHz, adc resolution is 12bit. I set up an LVDS_RX megafunction with the f...
14 years ago1. As captainliuy said, try to connect frame clock from ADC to LVDS_RX megafunction, because now I can see (in attached screenshot) you are using bit clock.
2. Have you constrained properly this project? Cause I had similar problem. When I constrained LVDS part the problem was gone. (I used frame clock) 3. You are sure, there are no errors on PCB?
