10 years agoLVDS output High Z or both to '0'
Hi, I have LVDS output. Is there a any way to put both LVDS outputs to High-'Z' or either both driving '0' ? -Tero
10 years agoTristateable Bus LVDS drivers are always emulated LVDS. There should be no basic problem (besides some timing drawbacks) to connect it trough logic gates.
--- Quote Start --- Bus LVDS (BLVDS) output uses two single-ended outputs with the second output programmed as inverted. --- Quote End ---
