15 years agoLVDS cycloneII to 10 bit counter
In cycloneII manual i read the max freq input LVDS pin is >800MHz. IF i have a 750 MHZ signal as input, and i send it to LVDS input (cycloneII), can i divide this freq with a 10-bits counter? ...
15 years agoHi Thieulam,
If it really is a 750MHz clock signal that you want to slow down, then it is too fast for the FPGA I/O pins. You would need an external divider. Micrel make plenty of high-speed dividers. Check the Cyclone II data sheet for the PLL specifications. You could divide your clock down to the PLL reference fmax, and then route the divided signal to a PLL reference pin. Alternatively, divide the clock down to below the I/O pin maximum frequency. What do you hope to do with this signal once you get it into the FPGA? Cheers, Dave
