10 years agoLVDS critical warning
hello I got many warnings which are ... "ID:12887 Too many 2.5-V SE IO in bank <name> with LVDS RX pin <name>. Reduce the number of 2.5-V I/Os used and re-run the analysis again. ...." a...
10 years agoIf you search on that warning in the knowledge base you'll find this:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10102013_979.html Read this and follow the links and it should explain what you need to do.
