13 years agoLPM_ShiftReg block doesn't work?
today I upgraded to altera V12.1-177. I created a new LPM SHIFTREG block with a load pin and a clock pin. The block has an 8-bit bus input and an 8 bit bus output. That being said I have tried I introducing an 8 bit byte at the input and and the byte can be seen at the output. However, the block ignores any input signal at the load pin. Dido if I use a clock enable. it seems the block does not pay attention to any control lines such as the load, clk enable or clocks??? anyone else experiencing this? rNo RepliesBe the first to reply
