LPM_MULT not working for Cyclone 10 GX device
- 1 year ago
I could strip down the design, but I have some new information. I was able to work around the issue by changing the implementation style to "Use logic elements", in lieu of "Use the default implementation" or "Use the dedicated multiplier circuitry". I believe the default implementation is to use the dedicated multiplier circuitry. I think there really is a bug in the Altera LPM_MULT IP when using multiplier blocks.
Changed to "Use loigc elements"Signal Tap showing ckt works as expected
No. We've visited this issue before. The IP wizard instantiates lpm_mult. I've shown you the code it created. I don't see the point of doing this standalone. Perhaps you can tell me why a standalone instantiation would be any different from the IP wizard instantiation. The IP wizard creates a wrapper. I would just be removing the wrapper.
