10 years agoLPM Divider execution time
What is the maximum time to perform a division with Altera LPM_DIVIDE without clock (only combination divider). I am using only unsigned integers and I don't care about the remainder. The numerator i...
10 years ago --- Quote Start --- My system clock is 3MHz, that means to have a result in one system clock cycle can i use I higher clk (for example 10Mhz) for the divider with pipeline? --- Quote End --- No, it does not mean that. You need to run the timing analysis to see if your circuit will work in the way you've configured it. But at 3Mhz, the divider will probably meet timing with a pipeline length of 1.
