10 years agoLPM Divider execution time
What is the maximum time to perform a division with Altera LPM_DIVIDE without clock (only combination divider). I am using only unsigned integers and I don't care about the remainder. The numerator i...
10 years ago --- Quote Start --- There is no "time". If you go without a clock then the propgation delay will be affected by PVT (process, voltage, temperature) and routing meaning every time you compile it the prop delay will be different. And to top it all off, you have no idea how long it takes before it would be stable as there is no way to measure it. With a clock, you can measure all these things and you know the "turnaround" time. And to top things off, the higher the pipeline delay, the faster the clock speed you can achieve. --- Quote End --- My system clock is 3MHz, that means to have a result in one system clock cycle can i use I higher clk (for example 10Mhz) for the divider with pipeline?
