15 years agolpm_divide remainder result
My thread is mainly on the remainder output from the lpm_divide. I am using the lpm_divide megafunction for diving two 16 bit fixed point numbers and the denominator is always greater than or ...
15 years agoThat's correct you should get that value as the remainder. As a result I would prescale the numerator more than the denominator so that you get a quotient that is beyond 0 or 1 (otherwise you don't really need a divider to figure out the answer....)
